-5V PSU out of +5V or +9V
neazoi
Advanced Member level 6
Greece
Hello,
I am trying to find a schematic for a -5V PSU that can be derived from +5V or +9V input voltage. Current consumption is about 300-500mA. My transformer has not gor a center tap. I would like to use a +9v from a jack wall
I am going to use this to feed some opamps
The simplest the better, I would prever the use of linear regulators.
Thank you
You can use MAX660 by National Semi. Works good. Check the datasheet for details. Are you sure your op-amps will consume 300-500mA? Try to verify that with a table top dc power supply.
Reactions: neazoi
    neazoi
I am trying to make a circuit to replace this one. I would make this one if I could find the details of the coil used.
I avoid MAX chips because maxim stops the production of specific types afrer some years.
the series that i gave you is easily replaceable by other manufacturers like Maxim/National/Linear/Intersil, with varying performance for same pinout ... you should have no issues in finding a replacement. In any case the manufacturer is National and the part is very popular
Reactions: neazoi
    neazoi
is there a military ceramic package version of it?
i dont think so .... check the datasheets and websites of manufacturers quoted above ... you should be able to find something of interest
Reactions: neazoi
    neazoi
The easiest method would be to use a 9Vdc wall adapter just for the -5V regulator. They're cheap too.
Reactions: neazoi
    neazoi
Easiest way to get -5V from +9V is to use Voltage regulator 7905.
Reactions: neazoi
    neazoi
Ignore Saikat36's last reply, it's nonsense!
The 7660 and it's clones has been available for years and will be around for a long time yet. The schematic you show is to generate +12V as well as -5V so it is more complicated than necessary. Your current requirement is quite high so the schematic wouldn't manage to cope anyway. I suggest you look at DC-DC converters which you buy as small plastic packages and have isolated outputs. Either you could get one with "+5 0v -5V" which has the advantage that the + and - outputs track each other, this might help to keep op-amp center rails at 0V, or you can get a single +5V output and reverse the output pins so it gives you -5 out. The outputs are isolated from the input supply so it's quite safe to do that.
Brian.
Reactions: neazoi
    neazoi
The DC-DC converters mentioned by Brian usually are described as being 'awesome'/'great' depending on manufacturer. You will get them for all sorts of specifications for +/-5V output. But they also tend to cost a little more than other options.
I still recommend that you try out the circuit with a lab power supply (opamps using 800mA current seems a little too much), get the optimum current requirement and then evaluate the options given in this forum.
Reactions: neazoi
    neazoi
You cannot. the 7905 requires a negative input voltage.
---------- Post added at 13:16 ---------- Previous post was at 13:15 ----------
Thanks a lot guys
Sorry for unintentionally giving wrong information.
Reactions: neazoi
    neazoi
Here's a clever method to obtain a negative supply from positive pulses.
www.edaboard.com/attachments/8893d1115569736-555_179.gif
Also:
newelectronicdesings2011.blogspot.com/2009/11/negative-supply-from-single-positive.html
Provides low power only. If you want more than a few mA...
Then you'll send the oscillator pulses to drive a mosfet. It will chop the pure + supply DC. Then you send that through the conversion stage. Use higher value capacitors depending.
Reactions: neazoi
    neazoi
Your procedure is too messy to implement mate.
Can anybody suggest atleast simpler process than that?
Reactions: neazoi
    neazoi
Also:
I have seen that before. It works, but only for low current. I do not believe it can provide 300-500mA of current as it is.
I am interested to see the final though
Now that I refresh my memory using the circuit simulator...
To get more power it won't work to simply chop the supply with a mosfet.
The device that provides pulses has to both source and sink current.
More like a hi power op amp. It must have very low ON resistance at the output pin.
Reactions: neazoi
    neazoi
Take a look at MAX 774 from Maxim , Inverting Switching Regulator (without Transformer) , -5 V 1A out , 3~16.5V input.
Datasheet Link : **broken link removed**
I used MAX764 (0.26A Version) and it works like a charm.
Good Luck!
Reactions: neazoi
    neazoi
These integrated solutions all work I am pretty sure and thank you.
Has anyone seen a way todo it using discrete components and avoiding the tapped coil?
Look up the 8 pin IC called MC34063A, they are very inexpensive and can be wired to provide a regulated step-up, step-down or voltage inversion with a negative output in excess of 100mA. The data sheet shows how to do it and you only need one single coil inductor which you can buy or wind yourself.
Brian.
