TsAmE
Junior Member level 3
Design a 555-based monostable which outputs a constant pulse 3.3s long each time a button is pressed (whether the button is pressed briefly or held down). Use a 1µF timing capacitor. Indicate all component values. What voltage should be applied to pin 5 to double the output pulse duration?
Refering to the attachment of the correct answer I would like to know:
*Why the 0.1µF capacitor was included, as it said nothing about it in the question.
*The answer for the voltage applied to pin 5 = 7.78V. How do you calculate this?
