I want to design a remote control which read two buttons from remote and run 2 TTL logic on receiver. The range of operation is very short. But I am restricted to use on 433MHz band.
The best method I find to use OOK with 433MHz transmitter and a Schmidt trigger at the receiver. Please suggest any working circuit. The power supply is 2V minimum at both receiver and transmitter.
Please provide if you have any suggestion.
Thanks in advance.
Nowadays, with so many devices emitting carriers everywhere, I would say that this kind of 'coding' should be abandoned. If you want something that gives you a minimum of security, it is better to consider some standard IC encoder/decoder for RF circuit like those used in remote control of the family HT6026 for example.
