Availability of IO Pads
fragnen
Full Member level 4
The IO Pads are present in rtls. To realize these IO Pads we require gates.
Do foundries provide the .lib/library of IO Pads separately from standard cells and macros?
Can this IO pad library be provided during synthesis of rtls?
Are these IO Pads are available from any other place other than foundry?
Yes, it is separate library.
Yes, it can. But, these pads should be included in your RTL.
Yes, there are some companies that sell IO pads (as well as other IPs).
Is this IO Pad library also available as a merged library with the standard cells library so that in a single .lib both standard cells and IO Pads be available?
How can we identify an IO Pad library? Does it has a typical name extension which helps to identify an IO Pad library by just seeing the file name of the IO Pad library?
When should the IO Pad library cells should be inserted in netlist as a industry standard design flow? Is it the IO Pads are inserted first in netlist during synthesis of rtls as an industry standard design flow?
[/QUOTE]
LaTeX Commands Quick-Menu:
