Eugen_E
Full Member level 6
4046 pll
I'm using the 4046 PLL with type 2 phase comparator (I need full VCO range lock)
with external VCO, at about 100kHz.
To make a stable PLL i use the classical lead-lag filter with 2 resistors and 1 cap with enough damping.
The question is how I can attenuate enough the pulses from the phase detector that reach the VCO input ? If I damp enough the loop for stability, the filter attenuation would be too low.
Can I use another RC filter after the lead-lag filter, with pole frequency much higher than that of the lead-lag?
The lead-lag pole is at 100Hz, and I added an RC LPF with a pole at 3kHz, but to my surprise the loop can't lock in this case and the frequency fluctuates around the correct value.
