4 ROW ALPHANUMERIC LCD MODULE
vamanan
Full Member level 2
India the Great
Dear Friends,
I am in the process of interfacing a 4 row x 20 char LCD with 8051 controller.Can anybody send me some details how to do it.
Thanking You.
Regards,
Vamanan
tell me what microcontroller you intend to use, if you use at89s8252, I have a diagram schematic and software in Assembly and C
Dear aldevan I am using 89c51 philips.So please give me the schema and code.
Thanking you
the source in assembler was assembled with metalink and source C was Compiled with sdcc, if you get problem to compiller, tell me and I send HEX file
    vamanan
Dear Friend Aldevan,
Thank you very much for your timely help.It worked for me.
Even then I had some problem in reading the pdf file since it is in some other language, I just understood the assembly code and now my LCD module is working fine.
Thanking you again.
