Can I use N type Mosfets to make a H-Bridge? I made one using Z44N power Mosfets which are N type Mosfets but I am having Problems.
The problem is with the side of the bridge on which the high mosfet has to be turned on and the lower Mosfet has to be turned off. When I ground the gate of the lower Mosfet to turn it off and apply Vcc (9V) to the gate of Higher Mosfet to turn it on,the Vgs voltage of the Higher Mosfet is not greater than Vt because the lower Mosfet is Off !!! so it doesnt turn on properly.
I have seen circuit diagrams in which 2 P type Mosfets were used for the high side and 2 N type were used fo the low side. But cant I use all four Mosfets of N-Type? If there is any way to do so please tell how.
Also I found this schematic on the site h**p://www.4qdtec.com/bridge.html. In it all the Mosfets used are N-Type is the schematic wrong ??
