franticEB
Full Member level 3
- Joined
- May 10, 2010
- Messages
- 153
- Helped
- 1
- Reputation
- 2
- Reaction score
- 2
- Trophy points
- 1,298
- Activity points
- 2,551
Very unusual.
It is a classical lowpass with a series capacitor at the input that attenuates low frequencies and dc.
You are asking for the center frequency - but how do you define (in this 3rd order case) the center frequency?
Edit: Classical bandpass responses are of 2nd order (or n=4,6...).
In this (unusual) case with n=3, you have two possible choices for defining the center frequency: maximum of transfer function or phase shift of 225 deg (mid between +90 and 360)
Your circuit is, in fact, a second-order lowpass in series with a coupling cap that introduces a highpass response.I were also thinking about low-pass + decoupling cap that acts as high pass.
So if i want to move the cut-off frequency pole with the general effect to enlarge the band of HighPass+LowPass filter, what i have to do?
The plus and minus signs of the opamp are placed incorrectly. I mean, in this way, the filter can not produce complex poles. This circuit is just a cascade of a second order low pass filter with a first order high pass filter. View attachment 93043
First of all i don't understand why the knee is @19KHz, since the cutt-off freq is @86KHz, and then i want to move that 19KHz to 20KHz/21KHz(i.e. the filter has to begin to attenuate after 20 KHz)
