toognitti
Newbie level 3
This question is regarding 3-wire 4-20mA current loop transmitting
I have purchased 2 ICs from TI; the XTR 110 and XTR 111
neither of them could transmit the signals i wanted when connected according to the circuits provided in the datasheets.
I researched a bit and found that unlike a 2-wire transmission which is powered from the loop,
the 3 - wire need an external source for the supply voltage, i.e it cannot be powered directly from the loop.
So my question is; is it possible to transmit a 4-20mA signal using 3 wires without using an external voltage source as a supply?
and furthermore is this possible using the XTR 110 or 111?
