3-to-6 decoder task problem- behaviour definition, diagram
funjoke
Member level 3
help with 3-to-6 decoder
a 3-to 6 binary decoder has an enable signal.When disabled or invalid code is applied to the decoder ,the decoder will output zeros.When enabled,input codes from 000 to 101 are decoded.Draw the block diagram of 3-to-6 decoder and define its behaviour using a truth table.
may i know how to do this question ?
CMOS
Advanced Member level 3
USA
Re: help with 3-to-6 decoder
Looks like your homework question. Did you gave it a try?
Let us know how far did you reach, we can help you out then.
You will not learn anything from ready solutions.
    funjoke
funjoke
Member level 3
this is pass year question.and i just know how to do 2-to-4 decoder.this one i really dunno
CMOS
USA
Ok. Here is the solution.
C(MSB), B, A(LSB) are the three select inputs.
ENABLE is Active high.
Outputs are all active high.
Last two input codes 110 and 111 are invalid inputs which produces 0 on all outputs.
| Truth Table |
| C        B        A     ENABLE      Q0       Q1       Q2       Q3       Q4       Q5 |
| X        X        X        0        0        0        0        0        0        0  |
| 0        0        0        1        1        0        0        0        0        0  |
| 0        0        1        1        0        1        0        0        0        0  |
| 0        1        0        1        0        0        1        0        0        0  |
| 0        1        1        1        0        0        0        1        0        0  |
| 1        0        0        1        0        0        0        0        1        0  |
| 1        0        1        1        0        0        0        0        0        1  |
| 1        1        0        1        0        0        0        0        0        0  |
| 1        1        1        1        0        0        0        0        0        0  |
funjoke
Member level 3
what is the module definition of the 3-to-6 decoder?
Added after 1 minutes:
the block diagram is like that ?
this is the circuit i think
Added after 27 seconds:
CMOS
USA
What i showed above is the actual circuit using NOT and AND gates.
If Verilog module is what you are asking for, here it is
// 3-to-6 decoder with an active-high enable (E)
// and active-high outputs (C is msb and A is lsb)
module _3_to_6_decoder(C, B, A, E, Y);
	input C, B, A, E;
	output [0:5] Y;
	reg [0:5] Y;
	always @(C or B or A or E) begin
	if (E == 1)
		case ({C,B,A})
			3'b000:   Y = 6'b000001;
			3'b001:   Y = 6'b000010;
			3'b010:   Y = 6'b000100;
			3'b011:   Y = 6'b001000;
			3'b100:   Y = 6'b010000;
			3'b101:   Y = 6'b100000;
			default:  Y = 6'b000000;
		endcase
	else Y = 6'b000000;
	end
endmodule
funjoke
Member level 3
write if only to describe 3- to-6 decoder
here i attached the answer for it and can help me checked and correct it if there is any error
(output reg[5:0] op_y,
input [2:0] ip_a,
input ip_en);
always@(ip_en,ip_a)begin
if(ip_en == 2'b1)begin
if(ip_a == 3'b000)op_y=6'b000001;
else if(ip_a == 3'b001)op_y=6'b000010;
else if(ip_a == 3'b010)op_y=6'b000100;
else if(ip_a == 3'b011)op_y=6'b001000;
else if(ip_a == 3'b100)op_y=6'b010000;
else if(ip_a == 3'b101)op_y=6'b100000;
else if(ip_a == 3'b110)op_y=6'b000000;
else if(ip_a == 3'b111)op_y=6'b000000;
else op_y=6'bx;
end
else if(ip_en ==2'b0)
op_y=6'b000000;
else
op_y=6'bx;
end
CMOS
USA
Since ip_en is 1 bit you should use 1'b1 and 1'b0 instead of 2'b1 and 2'b0.
Why do you tri-state outputs when input is invalid? The question said outputs should be 0.
Here is the optimized version
input [2:0] ip_a,
input ip_en);
if(ip_en == 1'b1)begin
	else op_y=6'b000000;
	end
else
	op_y=6'b000000;
end
funjoke
Member level 3
but just now you gave that code is which part
now got 2 part for this question
a)module definition
b)use case only to describe it
CMOS
USA
a)module definition
I am sorry I don't understand your question. Can you please re-phrase it?
daviddlc
Full Member level 5
USA
mmm, this post has been already too long for a pass year question.....
CMOS
USA
I know right !! :wink:
funjoke
Member level 3
input C, B, A, E;
output [0:5] Y;
reg [0:5] Y;
if (E == 1)
case ({C,B,A})
endcase
else Y = 6'b000000;
end
endmodule
i mean this one is module definition or using case to describe ?
CMOS
USA
If I get it right what you are asking. Both the module definitions will work.
You can either user "if-else" or "case". Your choice.
funjoke
Member level 3
by the way what is mean by module definition ?>
funjoke
Member level 3
can anyone explain with me what is the module definition ?
CMOS
USA
Looks like you are not very familiar with Hardware Description Language.
Read Verilog / VHDL tutorials.
A module is nothing but a circuit meant to perform a certain logical operation.
funjoke
Member level 3
Re: 3-to-6 decoder task problem- behaviour definition, diagr
if using for to describe it ,
here is my answer
integer i_position;
always@(ip_a,ip_en)begin
if(ip_en==1'b0)
op_y=6'b000000;
else if(ip_en==1'b1)begin
for(i_position=0;i_position<6; i_position=i_position+1)
if(ip_a==i_position)
op_y[i_position]=1'b1;
else if(ip_a!=i_position)
op_y[i_position]=1'b0;
else
op_y=6'b000000;
end
else
op_y=6'b000000;
end
end module
can help me check correct a not ,thanks
