#include <p18f4520.h>
// High priority interrupt vector
void chk_isr(void);
void InitTimer0(void);
void InitTimer1(void);
void InitTimer3(void);
void Run_Motor1(void);
void Run_Motor2(void);
void Run_Motor3(void);
#pragma interrupt chk_isr
void chk_isr(void)
if(INTCONbits.TMR0IF) Run_Motor1();
if(PIR1bits.TMR1IF) Run_Motor2();
if(PIR2bits.TMR3IF) Run_Motor3();
#pragma code My_HiPrio_Int = 0x08 // store the below code at address 0x08
void My_HiPrio_Int(void)
_asm
GOTO chk_isr
_endasm
#pragma code
char FullStepForward1 [4]={0x03, 0x09, 0x0C, 0x06};
char FullStepBackward1[4]={0x06, 0x0C, 0x09, 0x03};
char FullStepForward2 [4]={0x03, 0x09, 0x0C, 0x06};
char FullStepBackward2[4]={0x06, 0x0C, 0x09, 0x03};
char FullStepForward3 [4]={0x03, 0x09, 0x0C, 0x06};
char FullStepBackward3[4]={0x06, 0x0C, 0x09, 0x03};
char data1,data2,data3;
int M1_ADC,M2_ADC,M3_ADC;
char Index1=0;
char Index2=0;
char Index3=0;
char status1=0;
char status2=0;
char status3=0;
char M1Forward=1;
char M2Forward=1;
char M3Forward=1;
void main ()
TRISA=0xCF;
PORTA=0x00;
TRISB=0x07;
PORTB=0x00;
TRISC=0x00;
PORTC=0x00;
TRISD=0x00;
PORTD=0x00;
TRISE=0x00;
PORTE=0x00;
ADCON0=0x01;
ADCON1=0x0B;
ADCON2=0xAE;
InitTimer0();
InitTimer1();
InitTimer3();
PIE1bits.TMR1IE=1;
PIR1bits.TMR1IF=0;
PIE2bits.TMR3IE=1;
PIR2bits.TMR3IF=0;
INTCONbits.TMR0IE=1;
INTCONbits.TMR0IF=0;
T0CONbits.TMR0ON = 1; // Timer0 on
T1CONbits.TMR1ON = 1; // Timer1 on
T3CONbits.TMR3ON = 1; // Timer3 on
INTCONbits.PEIE=1;
INTCONbits.GIE=1;
M3_ADC=512;
while(1)
ADC_ALL();
void ADC_ALL()
ADCON0bits.ADON=1;
ADCON0=0x09; // Use AN2 for motor 1 speed control
ADCON0bits.DONE=1;
while(ADCON0bits.GO==1);
M1_ADC=ADRESL+(ADRESH*256);
ADCON0bits.ADON=0;
if(M1_ADC>20 && status1==0){
status1=1;}
else if (M1_ADC<20) {
T0CONbits.TMR0ON = 0;
status1=0;}
Time_5ms();
ADCON0bits.ADON=1;
ADCON0=0x0D; // Use AN3 for motor 2 speed control
ADCON0bits.DONE=1;
M2_ADC=ADRESL+(ADRESH*256);
ADCON0bits.ADON=0;
if(M2_ADC>20 && status2==0){
status2=1;}
else if (M2_ADC<20) {
T1CONbits.TMR1ON = 0;
status2=0;}
void Time_5ms()
int Delay;
for(Delay=0;Delay<10000;Delay++);
void InitTimer0(){
T0CON = 0x04;
TMR0H = 0xCC;
TMR0L = 0x5E;
void InitTimer1(){
T1CON = 0xB4;
TMR1H = 0x2A;
TMR1L = 0xE5;
void InitTimer3(){
T3CON = 0xB0;
TMR3H = 0x0A;
TMR3L = 0xE5;
void Run_Motor1()
unsigned char UpData,DownData;
unsigned int value;
INTCONbits.TMR0IF = 0; // Motor1 control with Timer0
value=(M1_ADC * 9)+55000; // Delay value accroding ADC input;
DownData=value;
UpData=(value-DownData)/256;
TMR0H = UpData;
TMR0L = DownData;
if(M1Forward)LATC=(PORTC & 0xF0) | FullStepForward1[Index1];
else {LATC=(PORTC & 0xF0) | FullStepBackward1[Index1];}
Index1++;
if(Index1==4) Index1 = 0;
void Run_Motor2(){
unsigned int value;
PIR1bits.TMR1IF = 0; // Motor2 control with Timer1
value=(M2_ADC * 26)+35000; // Delay value accroding ADC input;
DownData=value;
TMR1H = UpData;
TMR1L = DownData;
if(M2Forward)LATC=(PORTC & 0x0F) | (FullStepForward2[Index2]<<4);
else {LATC=(PORTC & 0x0F) | (FullStepBackward2[Index2]<<4);}
Index2++;
if(Index2==4) Index2 = 0;
void Run_Motor3(){
unsigned int value;
PIR2bits.TMR3IF = 0; // Motor3 control with Timer3
value=(M3_ADC * 26)+35000; // Delay value accroding user input value by use of keyboard
DownData=value;
TMR3H = UpData;
TMR3L = DownData;
M3_EN=1;
if(M3Forward)LATB=(PORTB & 0x0F) | (FullStepForward3[Index3]<<4);
else {LATB=(PORTB & 0x0F) | (FullStepBackward3[Index3]<<4);}
Index3++;
if(Index3==4) Index3 = 0;
