Heya electronicman - I present one annotated picture:
The circuit as drawn is a typical halfway-between-a-schematic-and-layout circuit topology often seen in RF circuit design. If I had to guess, it has a decidedly "Agilent ADS" feel about it. Here, *every* copper feature is explicitly noted/drawn - such as the T-pieces used to form a junction between three conductors belonging to the same 'net'. As you've pointed out, it's a three stage amplifier - where each stage has individually adjustable/configured bias & power supply voltages.
The radial stubs are used to present low impedance 'shunts' to the frequency of operation, thereby aiding the decoupling of the AC and DC current paths. All vias are explicitly modelled (via a substrate and geometry specification - not shown).
It's a very generic design, and you'd need to know a lot more about the specifics of the active devices before you could create a functional layout from it.
Good luck!
