3 phase motor variable speed
Ludvig
Junior Member level 2
variable speed 3-phase motors circuit
Does anyone knows where to find schematic for triac or tyristor control of electrical 3 phase motors 5KW.
Rgds
Ludvig
billano786
Super Member
Full Member level 2
post your messages in appropriate sections
Stark
Member level 2
Member level 2
3 phase motor
which is your application?
Ludvig
Intend to reduce rpm on my lathe.
Mvbrgds ludvig
Teedy
Junior Member level 1
uk
i think you will struggle to do what you want with triacs / thyristors.
3ph motor speed is generally regulated by adjusting the frequency of supply through an inverter. using triacs, you would be reducing the voltage and therefore the output torque of your lathe, which is the last thing you want on a lower speed.
your best bet would be a 3ph inverter.
if you want to try triacs, something along the lines of a high power dimmer circuit x3 with a triple gang pot may work
gelly
regulator
hi
i think that building/designing your own inverter is not that simple
and it is not worth a try because of the costs...
example;
inverter Lenze type 8200 series or ev82 vector series costs
about 200 euro and have a lot of feutures
input = 230vac
output 3 phase
almost all is presettable...
speed,acc, dec,pole-pairs,dc brake...
built in filter, monitoring of current/power/voltage/frekw...
therefore i rater buy one for 200 euros than building one.
h**p://w*w.lenze.de
hope this helps.
greetz gelly
Stark
Member level 2
Member level 2
Three Phase Motor control
To control a three phase asynchronous induction motor you, in a direct mode,( not vector control) must keep constant the Voltage/Frequency ratio as long as possible up to a particular point of frequency (under 15 Hz usually) where it is possible yet to apply overvoltage boosting characteristic which offset decreasing of inductance and so a torque reduction(due to inductance reduction).The secret is to use a device which has three pulse width modulator (8 or better ten bit) and a computational core (more uCs can do this work or you can describe them in VHDL);so if you store in memory a sine look-up table which magnitude of produces the maximun of link voltage you can always modulate this magnitude in function of a frequency set taken from AD or a communication channel such UART or other.
Bye Stark
