Slen17
Newbie level 2
Hello all, I recently designed a 3 Bit gray code counter, however the simulation did not turn out as intended. Could any of you view my code and inform me as to where I went wrong. Thanks
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity counter_3bit_gray is port (Clock : in BIT; Reset : in BIT; Count_Out : out BIT_VECTOR(2 downto 0)); end entity; architecture counter_3bit_gray_arch of counter_3bit_gray is component DFF port (Clock : in BIT; Reset : in BIT; D : in BIT; Q, Qn : out BIT); end component; signal Q2_cur, Q1_cur, Q0_cur : BIT; signal Q2n_cur, Q1n_cur, Q0n_cur : BIT; signal Q2_nxt, Q1_nxt, Q0_nxt : BIT; begin Q2 : DFF port map (Clock => Clock, Reset => Reset, D => Q2_nxt, Q => Q2_cur, Qn => Q2n_cur); Q1 : DFF port map (Clock => Clock, Reset => Reset, D => Q1_nxt, Q => Q1_cur, Qn => Q1n_cur); Q0 : DFF port map (Clock => Clock, Reset => Reset, D => Q0_nxt, Q => Q0_cur, Qn => Q0n_cur); Q2_nxt <= (Q2_cur and Q0n_cur) or (Q2_cur and Q1n_cur) or (Q2n_cur and Q1_cur and Q0_cur); Q1_nxt <= (Q2n_cur and Q1n_cur and Q0_cur) or (Q2n_cur and Q1_cur and Q0n_cur) or (Q2_cur and Q1_cur and Q0_cur) or (Q2_cur and Q1n_cur and Q0n_cur); Q0_nxt <= Q0n_cur; Count_Out(2) <= Q2_cur; Count_Out(1) <= (Q2n_cur and Q1_cur) or (Q2_cur and Q1n_cur); Count_Out(0) <= (Q1_cur and Q0n_cur) or (Q1n_cur and Q0_cur); end architecture;
