aliyesami
Full Member level 6
I have built a powersupply for my microcontroller unit using
LM2575HV_3.3V but voltage is not stable. I am using it with the Meanwell LDD 770H 50v driver . If there is no load on the driver I get the voltage out put as 3.40 volts and if the driver is loaded the output voltage drops to 2.90 volts.
the chip spec is 3.3v so I am not sure how its producing 3.40 volts.
I have constructed the circuit as per datasheet specs
