3.3V driving 5V digital. how??
silver_sparrow
Member level 1
North Silicon Valley
What device do I need to help interface 3.3V digital output
to 5V input on CPLD???
I just have 3 signals to interface, with max freq of operation at 75MHz.
I would like to be able to buy the component from Digi Key.
Sparrow
Logic Compactibillity
Hy, try the single configuration called inverter with single transistor and resistr, its funny and work very well.
Gorkin
Use a level translator. Maxim have a few products. If the speed is not high enough you may need to build something with discrete components
E
Use SN74LVC3G07 which is an open collector 3 gate buffer from Texas.
Can work on voltage 2V6 - 5.0V. Ideal solution.
8)
If it is just for inputs meaning, if you are not required to connect the 5V output of CPLD to the 3.3V device, do you really have to use a level translator?
I think 3.3V will still drive a high on the TTL input pins.
Which type CPLD are you use?
Now may 5V cpld can be drived by 3.3V
Have a look at TI.
Interfacing the MSPxx device(3 V) to TTL.
There are a examples.
Divemen
I agree with it_boy and my_garden. Just look at the output and input specs of your device. For most CMOS CPLD inputs, > 2.0V means 'high'. So if your 3.3V output comes to say 3.0-3.1V, there is no need for level shifters.
I think you'll find the same in the TI document Divemen pointed out.
thnx for the responses, it was nice to share ideas on this.
the cpld is a -Al ter a- Flex10K.
-- one signal does not reach 3Vpp to the scope, that is why I wanted to
level shift before feeding.
I shall try to use a buffer to compensate from TI.
sparrow
