Aug 23, 2017 #1 R reza05 Junior Member level 2 Joined May 31, 2015 Messages 21 Helped 0 Reputation 0 Reaction score 0 Trophy points 1 Activity points 152 Hello, What is 2m,4m and 6m ferrite bead difference? Thanks.
Aug 23, 2017 #2 S smijesh Advanced Member level 1 Joined Sep 20, 2013 Messages 412 Helped 163 Reputation 326 Reaction score 163 Trophy points 1,323 Activity points 4,038 2mm, 4mm and 6mm are the inside diameter of ferite bead it will decide the cross section of core and possible size of feed through conductor. Probably bigger ID ferrite having more cross section hence high impedance
