2Dimension array of bit_vectors.Plz Help!!!
triggerman
Newbie level 6
I want to insert an image as an array in VHDL.I am new to the language so i the simplest thing i thought was this :
PACKAGE newtype IS
TYPE vector_array IS ARRAY (0 to 9,0 to 9) OF
BIT_VECTOR(7 DOWNTO 0);
END newtype;
USE WORK.newtype.ALL;
ENTITY test IS
PORT ( inp1 : IN vector_array);
END test;
ARCHITECTURE arch OF test IS
BEGIN
END arch;
The code above has no errors and do what i want to do but it uses many pins(800).So i want to ask if there is a solution to do the same thing(read an 10x10 array of bit vectors) but with less pins used.
Thanks in advance
