Dc motor speed control using pwm + pic16f877a
coolvasanth07
Member level 1
Hi, in my project i want to control dc motor using pwm...am using pic16f877a+hi-tech c compiler..it's urgent plz...
>>thanks in advance<<
Here an example of pwm setting but codes' explained in turkish still it will help you
  • PWM try.rar
>>thanks in advance<<
You can get what you need here: https://www.edaboard.com/blog/1812/
Circuit + Waveform:
//Programmer: Syed Tahmid Mahbub
//Compiler: mikroC PRO for PIC v4.60
unsigned int ADR;
void main() {
     PORTC = 0;
     TRISC = 0; //all PORTC pins output
     PORTA = 0;
     TRISA = 0x01; //RA0 input for pot
     CMCON = 7; //Disable analog comparators
     T2CON = 0; //Prescaler 1:1, TMR2 off
     ADCON1 = 14; //AN0 only analog
     ADC_Init(); //mikroC initializes ADC
     CCP1CON = 12; //PWM mode
     PR2 = 249; //16kHz PWM frequency
     while (1){
           ADR = ADC_Get_Sample(0) >> 2; //Get ADC reading for channel 0
           //and divide reading by 4
           if (ADR < 10){ //Setting lower bound
              TMR2ON_bit = 0; //Stop Timer and so stop PWM
              TMR2 = 0; //Clear Timer
              RC2_bit = 0; //Clear PWM output
           else{
                if (ADR > 240){ //Setting upper bound
                   RC2_bit = 1; //Keep PWM output high
                else{ //Within upper and lower bounds
                      CCPR1L = ADR; //Set PWM duty cycle
                      TMR2ON_bit = 1; //If not on, turn on TMR2. If on, keep on
Although the code there is in mikroC, you can very easily port it to Hi-Tech C.
Hope this helps.
Tahmid.
Thank u friends (tusemo and Tahmid )....thanx a lot....i got it.....
Dear Tahmid I have messaged u my code. Kindly chek that code. I dont know where the lies. I have read ur tutorials and made the accordingly but the PWM is not working I think.. I want to use fix pwm at 50%. It gives the pulse for some time but not untill the condition is satisfied. plz check my code.
