[Moved] For EEPROM programming how PIC16F877A is connected
bikash123
Member level 2
Tezpur University
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
// LCD module connections
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD module connections
void WriteEEPROM(char Addr, char Data);
char ReadEEPROM(char addr);
void port_confg();
 Lcd_Init();
Lcd_Cmd(_LCD_CLEAR);               // Clear display
Lcd_Cmd(_LCD_CURSOR_OFF);          // Cursor off
 void main()
 char WriteEEPROM(char Addr, char Data);
  port_confg();
  Delay_ms(2000);
   while(1)
 void port_confg()
 PORTB = 0;
 PORTA = 0;
 TRISB = 0b00001111;
 TRISA = 0b00100000;
while(EECON1.WR == 1);
EEADR = Addr;
EEDATA = Data;
EECON1.EEPGD = 0;              // 0 = Access data EEPROM memory
EECON1.WREN = 1;                // enable writes to internal EEPROM
EECON2 = 0x55;                  // Required sequence for write to internal EEPROM
EECON2 = 0xAA;                     // Required sequence for write to internal EEPROM
EECON1.WR = 1;                    // begin write to internal EEPROM
EECON1.WREN = 0;
EEADR = addr;
EECON1.EEPGD = 0;
EECON1.RD = 1;
asm nop; asm nop;
return EEDATA;
Re: For EEPROM programming how PIC16F877A is connected
I do not understand what you are asking - do you want to program an external EEPROM, or the internal one? This code is for the internal EEPROM. What do you want to know how to connect?
P.s. please use CODE tags when posting code. That is the '#' symbol on the message toolbar.
Yes, i would like to know how Microcntroller connect with LCD, so that EEPROM will display it.
The connections are in the code, assuming you are using an HD44780 compatible LCD. Lines 2 to 7 in the code, with the LCD being connected to the pins on port B as listed.
See also here for basic info and pinout on HD44780 LCD's: https://en.wikipedia.org/wiki/Hitachi_HD44780_LCD_controller
Note also that since the LCD RW pin is not defined, that pin on the LCD (pin 5) should be connected to ground to fix the LCD in write mode.
Pin 3 on the LCD (the contrast pin) is connected to the wiper of a 10k or higher potentiometer/preset, with the ends of the potentiometer connected between ground and +5V. That potentiometer is adjusted to get a display on the LCD.
but sir, why does lcd has not displayed it. i have connected it as per the references of microc. but the problem is i am unable to solve it before three days. where is the problem. I have connected AN2 as input by a potentio
