[SOLVED] 24V Control from 3.3V
tiwari.sachin
Full Member level 6
Full Member level 6
India
Hello,
I am trying to drive a load of 24V and control that line by using a P MOSFET (U1)
At gate of U1 I have a NMOS (2N7002) that control the gate signal
The sch is given in attachment
1. When I turn on Q1 but sending high to MECH_PWR_CNT, I get about 11V at Vg of U1
The datasheet of U1 is also attached.
The threshold voltage of U1 is -3V
Vgs = 11-24V = -13V (Here MOSFET should turn on but its not, I rather see a spike and that again goes to zero), the same thing is true when I turn Q1 Off but at negative side.
What am I doing wrong here
  • TJ20S04M3L_datasheet_en_20150227-1150567.pdf
How do you measure it? Scope? DVM?
Acidentally input in "AC mode"? --> use DC mode.
What load do you drive? Current? Capacitive, inductive?
What's the use of C3?
Gate-to-GND is not of interest, please tell us gate-to-source voltage. Don't calculate it, but measure it directly at the Mosfet.
Klaus
If Q1 is fully conducting you will get close to 0V at it's drain.
R1 & R2 therefore produce a potential divider across 24V and 0V.
So ~12V (really 12V + Q1 Vds) is what is expected. It works as designed.
If you want to kill the 24_MECH completely, use a lower value for R2 and consider using an NPN BJT for U1. If it is being used as a switch it shouldn't need a large heat sink.
Driving from 3.3V you are running perilously close to the Vgs threshold for a 2N7002, again, a bipolar transistor would be a better choice.
Brian.
SCOPE
It is DC
It will finally drive a motor and a thermal printer. Right now connected a resistor across.
It is NC
12V (ie Vs = 24V, Vg = 12V)
Right
Right
Right
What do you mean kill? Do you mean if I want drain voltage of U1 to go to zero when Q1 is turned off. If so then Yes, I do want that to happen.
I will try a transistor.
If you really measured 12V across the legs G-S of the MOSFET, then you don´t need to replace 2N7002.
--> When V_GS is about 12V, then measure the voltage between Drain and Source of the power Mosfet..
What about overcurrent and overvoltage protecton for the MOSFET?
Why don´t you simply use a protected high side switch? Also called smart high side power switch, PROFET, and similar. Can be directly driven from 3V3 logic signal.
Klaus
Its working now. The CRO Channel 1 wasn't working :(. I was trying this since yesterday :bang:
There still a problem. The drain voltage never goes to zero when I turn off Q1. It holds on 1.6V
Theres no protection on that
Good Option. Thx for suggesting. Do you know of any part numbers that can handle 24V @ about 5-6A and controlled by 3.3V
When the MOSFET is switched OFF, then this node is floating.
Floating voltage is not defined it may be any voltage between 0V and 24V.
Put a load (resistor) to get meaningful values. Or use a second transitor to switch the node to GND if you need this.
You want me to do the search for you? ;-)
Every manufacturer as well as many distributors should have free selection tools / tables. Use them. They are free to use.
Klaus
[When the MOSFET is switched OFF, then this node is floating. ]
Vs = 24V and Vg = 24V and hence Vgs should be 0V and MOSFET Off. What node are you referring to.
Not really :)
No harm in asking if you knew ;)
You talked about the drain voltage. --> Thus I referred to the drain voltage. This is the floating node.
Btw: When you quote, please use the "Quote" button. (top tool bar, right side, icon = speech balloon)
True. But we are in different continents. With different price and availability, ... and you have to look for a device that fits your requirements.
Thus I think it makes sense that every designer does the search on it´s own.
It doesn´t take more time than posting all the requirements in a froum .. and you get best and fastest feedback.
Klaus
Sure.. Will do that.
Thanks for your help. Appreciate it :)
