pwm proportional solenoid valve + switch mode power supply
kovibb
Member level 1
Hi
I have also one question to you. Can I joint this two circuits (A3942 and **broken link removed** afraid of damage or oscillation? It is connection between switched supply and solenoids driver. Load in one branch is 60ohm resistor and cca 10mH inductance. Requirement of output is 24V and 400mA max. What is generally danger of this connection? please help me or give me advice. Thank you
