240X240 LCD monocrome dot matrix SAP3305 controller
london
Member level 4
Hi Every body,
I am using MSP430F5435A to interface with SAP3305 LCD controller. I could not able to light up the LCD, Coud any one help me to see my code and correct. I am not sure it is because of timing issue. The SAP3305 controller and RA8835 are same.
the code is bellow,
#include <msp430x54xA.h>
#include "SAP3305.h"
#define LCD_PIN_CS 0x01 /* Chip Slect P2.0 O/P */
#define LCD_PIN_A0 0x02 /* Command/Data Select P2.1 O/P */
#define LCD_PIN_E 0x04 /* Chip enable P2.2 O/P */
#define LCD_PIN_RW 0x08 /* Chip Read/Write P2.3 O/P */
#define LCD_PIN_RST 0x10 /* reset P2.4 O/P */
#define LCD_PIN_D0 0x01 /* Register select P1.0 O/P */
#define LCD_PIN_D1 0x02 /* Register select P1.1 O/P */
#define LCD_PIN_D2 0x04 /* Register select P1.2 O/P */
#define LCD_PIN_D3 0x08 /* Register select P1.3 O/P */
#define LCD_PIN_D4 0x10 /* Register select P1.4 O/P */
#define LCD_PIN_D5 0x20 /* Register select P1.5 O/P */
#define LCD_PIN_D6 0x40 /* Register select P1.6 O/P */
#define LCD_PIN_D7 0x80 /* Register select P1.7 O/P */
#define LCD_DATA 0xFF /* P10.0 to 10.7 */
/* Writing value to DATA pins */
#define LCD_DATA_OUT(x) P1OUT &= ~LCD_DATA; P1OUT = (x & 0xFF)
/* pin LCD_PIN_CS setting to 0 or 1 */
#define LCD_CS(x) ((x) ? (P2OUT |= LCD_PIN_CS) : (P2OUT &= ~LCD_PIN_CS))
/* pin LCD_PIN_A0 setting to 0 or 1 */
#define LCD_A0(x) ((x) ? (P2OUT |= LCD_PIN_A0) : (P2OUT &= ~LCD_PIN_A0))
/* pin LCD_PIN_E setting to 0 or 1 enable Clock/ disable clock */
#define LCD_E(x) ((x) ? (P2OUT |= LCD_PIN_E) : (P2OUT &= ~LCD_PIN_E))
/* pin LCD_PIN_RW setting to 0 or 1 Data is write when RW low read when high */
#define LCD_RW(x) ((x) ? (P2OUT |= LCD_PIN_RW) : (P2OUT &= ~LCD_PIN_RW))
/* pin LCD_PIN_RST setting to 0 or 1 */
#define LCD_RST(x) ((x) ? (P2OUT |= LCD_PIN_RST) : (P2OUT &= ~LCD_PIN_RST))
#define MAX_KEY_COUNT 20
#define BYTE_PER_LINE 30
#define NUMBER_OF_LINE 240 //240X240
#define LCD_CD_CODE 1
#define LCD_CD_DATA 0
#define TIMER_COUNT 1000
//#define LCD_DATA P0
//sbit LCD_WR = P2^0; // R/W & CS
//sbit LCD_RD = P2^1;
//sbit LCD_CE = P2^2; // E
//sbit LCD_CD = P2^3; // A0
//sbit LCD_RST = P2^4; // RESET
//sbit SW_REV_SEQ1 = P2^6;
//sbit SW_SEQ1 = P2^7;
//sbit SW_REV_SEQ2 = P3^2;
//sbit SW_SEQ2 = P3^3;
#define MAXINITLCD 19 // 19 26
#define INIT_GRAPHICS 5
const unsigned char InitLcdCode [MAXINITLCD][2] =
LCD_CD_CODE, 0x40, //System Set
LCD_CD_DATA, 0x31, //P1 30
LCD_CD_DATA, 0x87, //P2 FX 8 pixel
LCD_CD_DATA, 0x07, //P3 FY 8 pixel
LCD_CD_DATA, 0x1D, //P4
LCD_CD_DATA, 0x25, //P5
LCD_CD_DATA, BYTE_PER_LINE, //P7 APL
LCD_CD_DATA, 0x00, //P8 APH
LCD_CD_CODE, SCROLL, //Scroll
LCD_CD_DATA, 0x00, //P1
LCD_CD_DATA, 0x00, //P2
LCD_CD_DATA, 0xF0, //P3 C0
LCD_CD_CODE, HDOT, //Scroll
LCD_CD_CODE, OVLAY, //ovlay
LCD_CD_DATA, OVLAY_P1+DM1, //P1 +DM1
LCD_CD_CODE, DISP_ON_OFF + DISP_OFF, //disp on off
const unsigned char InitGraphic [INIT_GRAPHICS][2] =
LCD_CD_CODE, CSRW,
LCD_CD_CODE, DISP_ON_OFF + DISP_ON, //disp on off
LCD_CD_DATA, 0x16, //P1
enum LcdDisp
LCD_SQUARE,
LCD_WHITE,
LCD_BLACK,
LCD_LETTER,
LCD_MAX
} LcdDisplay;
int OldLcdDisp;
int NewLcdDisp;
int timer;
unsigned char uData0, uData1, uData2;
void InitLcd (void);
void LcdOutCommand (unsigned char ucData);
void LcdOutData (unsigned char ucData);
void InitReg (void);
void process (void);
void LcdSetAddress (unsigned char LcdAddrH, unsigned char LcdAddrL);
void UpdateLcd (void);
void LcdSquare (void);
void LcdSameGraphData (unsigned char ucData);
void LcdLetter (void);
int __low_level_init(void){
WDTCTL = WDTPW+WDTHOLD; // Stop WDT
return 0;
void main(void)
// Stop watchdog timer to prevent time out reset
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
InitReg ();
InitLcd ();
//LcdOutCommand(0x53);
process ();
__no_operation(); // For debugger
void process (void)
while (1)
UpdateLcd ();
//__bis_SR_register(LPM0_bits + GIE); // Enter LPM0, enable interrupts
//if (OldLcdDisp != NewLcdDisp)
OldLcdDisp = NewLcdDisp;
switch (NewLcdDisp)
case LCD_SQUARE:
// LcdSameGraphData (0xff);
LcdSquare ();
break;
case LCD_WHITE:
LcdSameGraphData (0x55);
break;
case LCD_BLACK:
LcdSameGraphData (0xaa);
break;
case LCD_LETTER:
// LcdLetter ();
LcdSameGraphData (0x17);
break;
int count1;
LcdSetAddress (InitGraphic [2][1] , InitGraphic [1][1]);
LcdOutCommand (MWRITE);
for (count1 = 0; count1 < 1000 ; count1++)
LcdOutData (0x0ff);
//LcdOutData (count1);
_NOP();
int nCharRow, nCharCol, nHeight;
int nCharacter;
for (nCharCol = 0; nCharCol < NUMBER_OF_LINE/8; nCharCol++)
for (nHeight = 0; nHeight < 8; nHeight++)
nCharacter = 0x30;
for (nCharRow = 0; nCharRow < BYTE_PER_LINE; nCharRow++) // mono no /3
LcdOutData(0x01); // mono char
nCharacter++;
unsigned char countCol, countSeg;
for (countCol = 0; countCol < 240; countCol++)
for (countSeg = 0; countSeg < 30; countSeg++)
LcdOutData (ucData);
// LcdOutData (countCol);
LcdOutCommand (CSRW);
LcdOutData (LcdAddrL);
LcdOutData (LcdAddrH);
LcdOutCommand (CSDIR);
void InitReg (void)
//P2 = 0xff;
//P0 = 0xff;
P2DIR |= (LCD_PIN_CS + LCD_PIN_A0 + LCD_PIN_E + LCD_PIN_RW + LCD_PIN_RST); //Set Control ports as Outputs
P1DIR |= (LCD_PIN_D0 + LCD_PIN_D1 + LCD_PIN_D2 + LCD_PIN_D3 + LCD_PIN_D4
+ LCD_PIN_D5 + LCD_PIN_D6 + LCD_PIN_D7); //Set Data ports as Outputs
P1OUT = 0x00;
NewLcdDisp = 0;
OldLcdDisp = LCD_MAX;
timer = 0;
void InitLcd (void)
int i;
LCD_RST(0);
for (i=0;i<100;i++);
LCD_RST(1);
//Init
for (i = 0; i < MAXINITLCD; i++)
if (InitLcdCode [0] == LCD_CD_CODE)
LcdOutCommand (InitLcdCode [1]);
else
LcdOutData (InitLcdCode [1]);
//Graphics
for (i = 0; i < INIT_GRAPHICS; i++)
if (InitGraphic [0] == LCD_CD_CODE)
LcdOutCommand (InitGraphic [1]);
else
LcdOutData (InitGraphic [1]);
//clear all data for 4 layers
for (i=0;i<0x5000;i++)
LcdOutData (0x00);
else
LCD_DATA_OUT(ucData);
LCD_A0(1);
LCD_RW(0);
LCD_E(0);
LCD_E(0);
LCD_E(0);
LCD_E(0);
LCD_E(1);
LCD_E(1);
LCD_E(1);
LCD_E(1);
LCD_RW(1);
LCD_A0(0);
LCD_RW(0);
LCD_E(0);
LCD_E(0);
LCD_E(0);
LCD_E(0);
LCD_E(1);
LCD_E(1);
LCD_E(1);
LCD_E(1);
LCD_RW(0);
sap3305.h
#ifndef sap3305_h
#define sap3305_h
#define SYSTEM_SET 0x40
#define SLEEP_IN 0x53
#define DISP_ON_OFF 0x58
#define SCROLL 0x44
#define CSRFORM 0x5d
#define CGRAM_ADR 0x5c
#define CSDIR 0x4c
#define HDOT 0x5a
#define OVLAY 0x5b
#define CSRW 0x46
#define CSRR 0x47
#define MWRITE 0x42
#define MREAD 0x43
//system set
//P1
#define SYSTEM_SET_P1 0x10
#define IV 0x20
#define WS 0x08
#define M2 0x04
#define M1 0x02
#define M0 0x01
//P2
#define WF 0x80
//Ovlay
#define OVLAY_P1 0x40
#define MX0 0x00
#define MX1 0x01
#define MX2 0x02
#define MX3 0x03
#define DM0 0x00
#define DM1 0x0c
#define OV 0x10
//Disp on off
#define DISP_OFF 0x00
#define DISP_ON 0x01
#endif
