24 VCC to 220 VCA converter
miguel_roque
Newbie level 2
Newbie level 2
I'm looking for a schematic of it, I need a power of 1 KW.
Some one help me
thanks a lot to all.
1k invertor 24V-220V
See here **broken link removed**
This scheme works, but it much not efficient - an inverse surge is suppressed by large number varistor and zener diode. Much better bridge schemes.
Yes, you can try , but don`t load more then 600W to converter.
You can also change current protections to 600W.
Bojan
aruljo said:
I need the 24vdc to 230vac 3000w circuit pls help
modify the above schematic.
change the transformer from 12-0-12 to 24-0-24
Added after 3 minutes:
you can try this simple cct
