230VAC operated Exhaust Fan Speed Control method
Golden Electronics
Full Member level 5
Full Member level 5
India
Dear Member,
I Require Exhaust Fan with following specification.
1. Speed control using external regulator or control
2. Operate on 230 VAC, 50 Hz
3. Size 9" or 12 "
4. application : Industrial Curing System
If u know any supplier or any solution please share
I wanted to control speed of a fan attached to our wood stove. I purchased a triac at Radio Shack. I constructed a circuit following the schematic. Very low cost. It worked.
I believe the fan was a 'squirrel cage' type. 120 VAC.
It drew little power so I did not need to put heat sinking on the triac.
I could suggest you this brand/models (Vario 9" or 12"):
They also make some external speed controllers:
I'm using some of their products (good quality stuff). You could surf their website for reference only - I'm sure there's other similar brands out there.
PS: Or are you looking for DIY solutions?
thanks for all reply. I use this in my one Industrial project. In which Fan use for air circulation cont. 24x7
