230v to 48v converter
sudarshann
Junior Member level 2
Hi Friends,
My question is very simple.
Input : 230V 50 Hz AC (India)
Output : 48V 5A
Please help me how can I do the above. I expect a usage of Solid State Devices for conversion. I have no idea where can start.
I am aware of commercial solutions but i need to design it for my project.
Thanks in Advance
Use a transformer to step down the 230VAC to 48V. Then use basic AC-DC circuit (diodes/capacitors). Just a thought...you can improve on the basics for your design.
Hi
I am not looking for a transformer based solution. I need a power electronics based solution.
any way thanks for a quick reply
Start by studying a good book on switchmode power supplies.
There are many good books, I particularly like Switching Power Supply Design, by A. Pressman, McGraw-Hill.
For your power level you must likely be using a Forward Converter Topology.
You have not mentioned whether you require power factor correction. If that is the case, the book above also describes it, but the app notes found in the Texas Instrument's website are your best bet.
Transformerless with a resistive-capacitive divider are good for a power output of a couple of watts at most.
The original poster on the other hand, requires 48 X 5 = 240 watt.
'Power Supply Cookbook' by Marty Brown is a good book to get started with...
