invexed
Junior Member level 2
- Joined
- Nov 1, 2001
- Messages
- 20
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 119
Hi, i need to know the best configuration to do a 200W with 85 to 250V input and 24V output power supply
I have try a push pull but with a TL494 control (cheap IC), need very high voltage Power mosfets but is a "simple" design (2 exciter signals are ground refered and no need isolated transformers)
With this configuration I need high capacity (2 or 3 nF) in clamping circuit to avoid high voltages
Is this a usual capacitor value ??? (i think should be 1nF or so...)
Bridge configuration (like PC power supply) is better but i need to isolate one transistor (with transformer, optocoupler... ).
Flyback maybe a good option but.... Is possible to handle this power ?
Where can I obtain commercial exciter transformers or supply transformers with multiple outputs to exciter circuits ?
I have try with a old PC power supply and all componets are ok but i can't
find this easily at the market
Power Fets are better than Transistors ?
Someone can help me... ????
What kind of IC control ?, Power transformer and all this...
Thanks......
Thanks......
