shreyas_patel21
Full Member level 3
I am using 2.8 inch LCD mtf0280qn with NIOS II processor.
the LCD uses HX8347D driver IC,
datasheet of this driver IC tells that it can be configure as 8 bit parallel or 16 bit parallel interface or many other by connecting pins IM0, IM1, IM2, and IM3 to VCC or ground,
but I have no any pins available at interface header strip. it has 37 pins as shown in mtf0280QN datasheet.
how can I know the interface of the LCD i.e. 8 bit parallel or 16-bit parallel?
thank you,
regards,
shreyas.
thank you,
regards,
shreyas.
