[General] 18F4520 Switch Input <Help>
Justin Hendrix
How do I read the status of switches (1 or 0) using a 18F4520?
#include <p18F4520.h>
void main ()
Regards.
Something like this. If there is a switch on RB0 then there are two ways depending upon how switch is connected.
Code C - [expand]
8
9
10
11
12
13
if(PORTBbits.RB0) {
       _delay_ms(50);
       while(PORTBbits.RB0);
             //do what you want here
if(!PORTBbits.RB0) {
       _delay_ms(50);
       while(!PORTBbits.RB0);
Hi Milan.rajak, thanks for the prompt reply.
Let's say I would like to connect it to an LED and that whenever the output is high (which is 1), the led will light up.
How do I do that in the script?
*P.S. Is it possible if you could come up with the full working script. I'd appreciate it a lot.
void main ()
Try this code. Connect an LED to PORTD.7, connect one end of switch to PORTD.0 and other end to +5V. Also connect one end of a resistor to PORTD.0 and other end to GND.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
#include <p18f4520.h>
#pragma config OSC = XT
#pragma config PWRT = ON
#pragma config WDT = OFF
#pragma config LVP = OFF
#pragma config DEBUG = OFF
#pragma config CPB = OFF
#pragma config MCLRE = ON
void Delay_ms(unsigned int);
void msdelay(unsigned int ms) {
    unsigned int x;
    unsigned int z;
    for (x = 0; x < ms ; x++)
        for(z = 0; z < 165; z++);
void main(void) {
    TRISD = 0x01;
    PORTD = 0X00;
    LATD = 0x00;
    while(1)  {
        if(PORTDbits.RD0) {
                Delay_ms(50);
                while(PORTDbits.RD0);
                LATDbits.LATD7 = ~LATDbits.LATD7
MPLAB X + C18 + Proteus 8.1 SP1 Project attached.
  • LED SW.rar
