embpic
Advanced Member level 3
hello frnds
i am using p89v51rd2 controller and keil compiler.
i am getting problem in busy flag . till now i used to use delay but it is not that much efficient so help me to use busy flag in 16x4 lcd. i tried but not working
and my code is
please correct my code.
thanx...
and my code is
sbit rs=P1^0;
sbit rw=P1^1;
sbit E=P1^2;
sbit d4=P1^4;
sbit d5=P1^5;
sbit d6=P1^6;
sbit lcd_st=P1^7;
void init_lcd()
delay(15);
command_write(0x03);
delay(5);
delay(5);
delay(5);
command_write(0x02);
delay(5);
command_write(0x28);
delay(5);
command_write(0x01);
delay(5);
command_write(0x0c);
delay(5);
void data_map(unsigned char ds)
unsigned char ab;
ab=ds;
P1=P1&0x0f;
ab=ab&0xf0;
P1=ab|P1;
void command_write(unsigned char c_dt)
lcd_status();
rs=0;
rw=0;
data_map(c_dt);
enable();
lcd_status();
rs=0;
rw=0;
c_dt=c_dt<<4;
data_map(c_dt);
enable();
void data_write(unsigned char d_dt)
lcd_status();
rs=1;
rw=0;
data_map(d_dt);
enable();
lcd_status();
rs=1;
rw=0;
d_dt=d_dt<<4;
data_map(d_dt);
enable();
void lcd_status()
unsigned char temm;
E = 0;
lcd_st = 1;
rs = 0;
rw = 1;
do
enable();
while(lcd_st==1);
rw = 0;
E = 0;
void delay (unsigned int val)
unsigned int n,m;
for(n=0;n<val;n++)
for(m=0;m<=120;m++);
void enable()
E =1;
delay_us(15);
E = 0;
void print(unsigned char *ptr,unsigned char addr)
command_write(addr);
// lcd_status();
while(!(*ptr=='\0'))
data_write(*ptr++);
// lcd_status();
thanx...
