hello people. Actually i´m working in a 16 fix array antenna but i have some problems. firts of all, i´m using a 8 patches array (because the simulation time is too much in my Pc...)which is the half of the final array which i want to get. The resonant frecuency will be the sames for a 16 fix array? . second question: i used an infinite ground plane in the simulation, is it a big mistake? , and finaly, i´m using a complete simulation, could i try with other type? the accuracy is good?
data: Er=2,5 (polystyrene), h=5 mm.
if someone have some advice... thank you very much!!
xeneixe
