module fxpt_adder(in1,in2,clk,result);
input clk;
input signed[32:0] in1,in2;
output signed [32:0] result;
parameter size = 33;
reg result_sign, sign1, sign2,sign_greater,sign_smaller; //sign_greater, sign_smaller;
reg [4:0] sig1, sig2;//significants of inputs -- 5 bits long
reg [5:0] result_sig;
reg [26:0] frac1, frac2;
reg [27:0] result_frac;
reg signed[32:0] result;
reg signed [32:0]in1_temp,in2_temp;
//assign in1_temp=in1;
//assign in2_temp=in2;
//assign in1_temp={sign1,sig1[4:0],frac1[26:0]};
//assign in2_temp={sign2,sig2[4:0],frac2[26:0]};
//assign result={result_sign,[5:1]result_sig,[27:1]result_frac};
always@(in1 or in2)begin
in1_temp=in1;
in2_temp=in2;
sign1 = in1[32]; //sign bit
sign2 = in2[32];
sig1 = in1[31:27]; //significand field
sig2 = in2[31:27];
frac1 = in1[26:0]; //fraction field
frac2 = in2[26:0];
sign_greater = (sig1 > sig2) ? sign1 : sign2;
sign_smaller = (sig1 > sig2) ? sign2 : sign1;
if(in1[32]==1)
in1_temp = {in1[32],!in1[31:0]+1};
else if (in2[32]==1)
in2_temp = {in2[32],!in2[31:0]+1};
end
always @(posedge clk)begin
if (in1 !=0 & in2!=0)
result_sign = sign_greater;
result_frac = frac1 + frac2;
result_sig = sig1 + sig2;
if(result_frac[27]==1)
result_sig = result_sig+1;
else if(result_sig[5]==1)begin
result_sig=result_sig[4:0];
result={sign_greater,result_sig[4:0],result_frac[27:1]};
end
end
endmodule
just try to undestand and make your code of 16bit
---------- Post added at 18:12 ---------- Previous post was at 18:02 ----------
here code is for 128 bit adder in verilog try and follow this definitely this will help you.
module adder_128bit (A, B, Sum);
input [127:0] A,B;
output [128:0] Sum;
wire [128:0] Sum;
wire [8:0] tempSum1, tempSum2, tempSum3, tempSum4, tempSum5, tempSum6, tempSum7, tempSum8;
wire [8:0] tempSum9, tempSum10, tempSum11, tempSum12, tempSum13, tempSum14, tempSum15, tempSum16;
wire tempCarry1, tempCarry2, tempCarry3, tempCarry4, tempCarry5, tempCarry6, tempCarry7, tempCarry8;
wire tempCarry9, tempCarry10, tempCarry11, tempCarry12, tempCarry13, tempCarry14, tempCarry15, tempCarry16;
wire f2, f3, f4, f5, f6, f7, f8;
wire f9, f10, f11, f12, f13, f14, f15, f16;
wire c1, c2, c3, c4, c5, c6, c7, c8;
wire c9, c10, c11, c12, c13, c14, c15, c16;
assign tempSum1 = A[7:0] + B[7:0];
assign tempSum2 = A[15:8] + B[15:8];
assign tempSum3 = A[23:16] + B[23:16];
assign tempSum4 = A[31:24] + B[31:24];
assign tempSum5 = A[39:32] + B[39:32];
assign tempSum6 = A[47:40] + B[47:40];
assign tempSum7 = A[55:48] + B[55:48];
assign tempSum8 = A[63:56] + B[63:56];
assign tempSum9 = A[71:64] + B[71:64];
assign tempSum10 = A[79:72] + B[79:72];
assign tempSum11 = A[87:80] + B[87:80];
assign tempSum12 = A[95:88] + B[95:88];
assign tempSum13 = A[103:96] + B[103:96];
assign tempSum14 = A[111:104] + B[111:104];
assign tempSum15 = A[119:112] + B[119:112];
assign tempSum16 = A[127:120] + B[127:120];
assign tempCarry1 = tempSum1[8];
assign tempCarry2 = tempSum2[8];
assign tempCarry3 = tempSum3[8];
assign tempCarry4 = tempSum4[8];
assign tempCarry5 = tempSum5[8];
assign tempCarry6 = tempSum6[8];
assign tempCarry7 = tempSum7[8];
assign tempCarry8 = tempSum8[8];
assign tempCarry9 = tempSum9[8];
assign tempCarry10 = tempSum10[8];
assign tempCarry11 = tempSum11[8];
assign tempCarry12 = tempSum12[8];
assign tempCarry13 = tempSum13[8];
assign tempCarry14 = tempSum14[8];
assign tempCarry15 = tempSum15[8];
assign tempCarry16 = tempSum16[8];
assign f2 = (tempSum2[7:0] == 8'hff);
assign f3 = (tempSum3[7:0] == 8'hff);
assign f4 = (tempSum4[7:0] == 8'hff);
assign f5 = (tempSum5[7:0] == 8'hff);
assign f6 = (tempSum6[7:0] == 8'hff);
assign f7 = (tempSum7[7:0] == 8'hff);
assign f8 = (tempSum8[7:0] == 8'hff);
assign f9 = (tempSum9[7:0] == 8'hff);
assign f10 = (tempSum10[7:0] == 8'hff);
assign f11 = (tempSum11[7:0] == 8'hff);
assign f12 = (tempSum12[7:0] == 8'hff);
assign f13 = (tempSum13[7:0] == 8'hff);
assign f14 = (tempSum14[7:0] == 8'hff);
assign f15 = (tempSum15[7:0] == 8'hff);
assign f16 = (tempSum16[7:0] == 8'hff);
assign c1 = tempCarry1;
assign c2 = (c1 & f2) | tempCarry2;
assign c3 = (c2 & f3) | tempCarry3;
assign c4 = (c3 & f4) | tempCarry4;
assign c5 = (c4 & f5) | tempCarry5;
assign c6 = (c5 & f6) | tempCarry6;
assign c7 = (c6 & f7) | tempCarry7;
assign c8 = (c7 & f8) | tempCarry8;
assign c9 = (c8 & f9) | tempCarry9;
assign c10 = (c9 & f10) | tempCarry10;
assign c11 = (c10 & f11) | tempCarry11;
assign c12 = (c11 & f12) | tempCarry12;
assign c13 = (c12 & f13) | tempCarry13;
assign c14 = (c13 & f14) | tempCarry14;
assign c15 = (c14 & f15) | tempCarry15;
assign c16 = (c15 & f16) | tempCarry16;
assign Sum[7:0] = tempSum1[7:0];
assign Sum[15:8] = c1 ? (tempSum2[7:0] + 1) : tempSum2[7:0];
assign Sum[23:16] = c2 ? (tempSum3[7:0] + 1) : tempSum3[7:0];
assign Sum[31:24] = c3 ? (tempSum4[7:0] + 1) : tempSum4[7:0];
assign Sum[39:32] = c4 ? (tempSum5[7:0] + 1) : tempSum5[7:0];
assign Sum[47:40] = c5 ? (tempSum6[7:0] + 1) : tempSum6[7:0];
assign Sum[55:48] = c6 ? (tempSum7[7:0] + 1) : tempSum7[7:0];
assign Sum[63:56] = c7 ? (tempSum8[7:0] + 1) : tempSum8[7:0];
assign Sum[71:64] = c8 ? (tempSum9[7:0] + 1) : tempSum9[7:0];
assign Sum[79:72] = c9 ? (tempSum10[7:0] + 1) : tempSum10[7:0];
assign Sum[87:80] = c10 ? (tempSum11[7:0] + 1) : tempSum11[7:0];
assign Sum[95:88] = c11 ? (tempSum12[7:0] + 1) : tempSum12[7:0];
assign Sum[103:96] = c12 ? (tempSum13[7:0] + 1) : tempSum13[7:0];
assign Sum[111:104] = c13 ? (tempSum14[7:0] + 1) : tempSum14[7:0];
assign Sum[119:112] = c14 ? (tempSum15[7:0] + 1) : tempSum15[7:0];
assign Sum[127:120] = c15 ? (tempSum16[7:0] + 1) : tempSum16[7:0];
assign Sum[128] = c16;
endmodule
