12v 7ah (ups battery charger)
user1111
Member level 3
charger 12v 7ah
does any body has charger for 12v 7ah sealed lead acid battery charger with over charging and low voltage prevention.
charger circuits using lm317 for 12v/7ah
the simple charger is using lm317 with constant volt abt 13.8 to 14.1 volt . in lm317 the current is limited by 1.5A.
Dear freind I have the circuit for the constant current and 13.6 v charger with over charging protector and deep discharging protector(9.1v) with CHARGE control and load protection when charging the battery
good , share it
where is it???
Re: charger 12v 7ah
Check this out - **broken link removed** - just follow exactly the calibration procedure and it will work perfectly. I know because i built one, i'm using it to charge my 12v 7ah SLA battery. I hope it suits your needs and good luck ;)
i am looking for 150ah charging system . chem is lead Acid.
i want more details about 12volt 7amp hour sealed lead acid battery ,can anybody send me the details regarding this
80~250V AC to 13.5V DC @10-15 Amps SMPS with 3842-43-44 (with Cutoff /3 LED indication)
  • Battery Charger.rar
If the Voltage being applied can be controlled (13.8v - 14.2V), what will happen if I try to charge 7Ah battery with unregulated current (constant) source of 4A ?
Please clarify this point as I have a simple SMPS with this configuration.
sorry for not here around for such a long time.... yes off course you can lower the current by Vr2.
