how to connect a microphone and process its signal in MATLAB
omidsht
Member level 2
matlab microphone
how to connect a microphone and process its signal in MATLAB in real-time ?
i want to connect a microphone to matalb and process the sound in real-time ( i want to do noise cancellation with adaline in real-time)
please help me
thanks
omid sharifi
matlab microphone input
For what I know Matlab is capable of processing .wav files, so you could acquire samples from MIC IN line and then process the wav file in Matlab to verify your algorithm, but I don't know how to do it in Real Time ... I suppose you have to customize the audio card driver to do it.
Regards
Mowgli
microphone matlab
please help me
thanks
omid sharifi
There's a comand in matlab called wavrecord to record from the mic input
X=wavrecord(N,FS,CH)
Where,
CH:Number of channels, means mono or stereo
FS:Sampling rate to get samples
N:Number of samples to record then it stops.
If N=10*FS, then matlab will record 10 seconds.
and X is a row vector of the recorded samples.
u can playback the vector X by the comand wavplay
wavplay(X, FS)
Hope that's useful
using matlab microphone
I suggest you to have a look in data acquisition toolbox. you dont have to work with .wav files.
matlab wavrecord
Is it for Active Noise Control?
Why don't you use a DSP it got RTDX (Real Time Data Exchange) feature
for further reference
DSP 6713 Rulph C
dsprelated.com
