engineer1000
I have a 135khz tranasducer attached to a generator. The generator has a choke on the output and when attached to a transducer forms a resonant circuit f= 1/2pi √LC.
When I run the generator the resonant point ie were the voltage amplitude across the transdcuer is greatest appears to be at 130.5khz.
Any ideas why?
Also C the static capacitance of the transducer =3.669nf I have a choke value of 278uH. The choke value can be measured straight across the transducer when attached to the generator. If I then measure capacitance the result is about 90uF which is wrong. So I have measured the static cap of the transducer whe nnot attached to the gen.
If I do the calculation to find out what value C should be it comes out at 5.3nF when runnnig at 130.5khz.
If this is the case I should be able to find the inductance value at 135khz. I have done this but find the activity is much better at 130.5khz
Any ideas why?
