GUGLHUPF
12v op amp
[I hope this was not answered before but welcome a pointer if it did]
Hi
I want to interface a +-12V OPAMP with a 5v Microcontroller and other 5V compnents in the same circuit board. I could think of the following methods but am unsure which one would work.
1) use a optocoupler board
I don't like this solution due to its increased cost and complexity in the system.
2) use 2 power supplies and connect the ground of the 5V to the ground of the 12V. I could isolate the 12V on the OPAMP and will take care the output does not exceed 5V.
I am not sure this would work.
3) use the +-12V power supply and a regulation circuit to reduce the +12V to +5V for the 5V logic system. Ground would be shared.
Can anyone advise which would work? My preferred method would be 3) as it means just a few components. Again I would make sure the OPAMP does not deliver 12V on it's output.
Thank you for your help.
Hi
