Jester
Full Member level 6
Is there any obvious reasons why this circuit would not get approved (safety wise)?
Assume the following:
- The fuse, MOV and C31 are safety approved parts.
- Digital Isolator is approved https://www.silabs.com/Support Documents/TechnicalDocs/Si861x-2x.pdf
- Enclosed in approved plastic enclosure
- Power supply on low voltage side is 5Vdc and approved
- Creepage between hazardous and low voltage side are adequate
- Circuit in hazardous domain requires less than 20ma
Should I be using a "X" cap or a "Y" cap for this application?
Choice for D2, D3, the peak current can be I believe 1.7A (power applied at peak of sinewave), however average current is quite low, Suggestions on a more suitable diode for D2, D3?
OPA4180 is rail to rail (output range includes -rail and within 1.5V of positive rail) https://www.ti.com/lit/ds/symlink/opa4180.pdf
Please feel free to critique in any way.
