Detailed description of the Deep N well
yaasi
Junior Member level 3
I would like to know about the Deep N-well.
Can anyone help me?
Thanks in advance.
Regards,
yaasi
Re: Deep N well
Simply speaking, use another n well implant between NMOS device and P substrate.The device has good isolation from the substrate.
Re: Deep N well
not only for isolation,but also for noise rejecting and latch-up effect
Deep N well
Deep N-well is not another n well.
detailed explaination can refer to the document of the foundry.
Deep N well
Good at substrate isolation at relatively low frequency!
Deep N well
basiclly, you can provide Pmos with different Nwell for bulk voltage, how about Nmos? With Deep newll you can do it too.
secondly, Deep Nwell can used as guardring
Re: Deep N well
You are right!
I mean it is another "N well implant".
Added after 3 minutes:
In fact, NMOS with deep N well is of more reality.
It's just another N implant between substrate and the device above.
It act as an isolation layer.
Re: Deep N well
Deep n-well is for the isolation. Guard rings can protect the horizantal currents but can not protect the vertical currents(which can travel deep in to the substrate and can couplr to the nearby sensitive circuits). So deep N-well can prevent vertical currents generated by the high power devices.Correct me if i'm wrong.
