100w -200w high power led driver using L6562-st electronics
emiljose88
Junior Member level 3
kerala,india
I wish to done 100w-200w led driver using L6562 IC in flyback topology. Is it good?
Do you actually need isolation if you're just delivering power to a LED? Are you running from 120/240V mains? Do you actually intend to use active PFC?
100-200W is somewhat high power for a flyback converter, but it can be done. You might also consider a forward converter.
