alltroid
Newbie level 1
This probably sounds like a odd use of a parallel or IDE port, but I was wondering it would be possible to have a grid of simple electric motors that are controlled threw a parallel or IDE port. Basically like how thousands of pixels are lit up threw a VGA cable witch has a limited number of pins.
I'm not sure if I need some kind of driver board or micro controllers or what. I don't know if there is some clever way of using a few pins to control a hundred motors without any extra drivers, etc.
basically my idea was to pinpoint each motor on the grid but that would require a ton of wires, but what I don't understand is how a LCD monitor for example can do this, I know it has a driver board, but if you look at the cables going out of the driver board and into the actual LCD panel, there is only a few not nearly enough for each pixel.
I'm planning on using a python module called PyParallel to interface with the parallel port.
I also just realized I cant use a IDE cable, at least not with python that I know of. However if I were to use a IDE cable, I was planning on using a old external hard drive case, the kind that still used a IDE ribbon cable, witch then plugs into the computer via USB.
Also i'm assuming with that I need some sort of protection between the motors and the parallel port?
thanks
thanks
