10 bit Differential, Bipolar input voltage ADC
Khan740
Junior Member level 2
I need 10 bit, Differential, Bipolar input voltage ADC. I have searched but could not find.
Range is not a problem, also number of input channels is not problem. I need this ADC for
pH meter.
What kind of search?
Did you go to maxim integrated and use their product selector.
did you try analog devices?
did you try TI?
did you try Linear Technologies?
did you try STMicroelectronics?
I found 10-bit ADCs on the first 2 sites using their product selectors. Seems like you didn't perform much of a search as the following search string points you to both the first two sites: "10-bit differential bipolar voltage ADC" and has URLs pointing to all of the above sites on the first page of results.
This makes me think you didn't even do a search.
