1-2 uS fixed width pulse for comparator output?
juz_ad
Full Member level 2
Full Member level 2
Is there an analog circuit other than a 555 that will convert the HIGH output of a comparator to a fixed-width pulse of approx. 1-2 uS?
I need a circuit that outputs a pulse when an input waveform goes above a VRef - but the output needs to be fixed width - so, independent from how long the signal stays above the VRef.
Thanks,
- J
It is called a One shot. These are your choices. You can always make a state machine with gates and a 1-2us reset using an RC delay with a Schmitt trigger
But often you need to consider noise less than your period and may want the added feature in One shots to be either non-retriggerable or re-retriggerable and thus extend duration from last threshold crossing.
Some have Schmitt trigger inputs.
if you need a specific threshold, then a comparator, with reference can drive the 1-shot
