shivakumar.r
Dear readers,
I am doing project which is used to controll heavy HP motors (nearly 10 HP).
I use 1/10th watt SMD resistors for my project.Recently i am facing issue of SMD resistor going bad.
After all the PCB soldering is done and if i measure the resistance value it is showing large values.
Example: I am using 100 ohm SMD resister at the output of current transformer for measureing the current.
after the PCB soldering is done if i measure this value it is showing 300 ohms.please help
