0-5V to 4-20mA Circuit
vamanan
Full Member level 2
India the Great
4-20ma circuit
Can anybody have the circuit to convert 0to5V to 4-20mA.Is there any ic's available?
4 20ma circuit
One other option is to employ a small microcontroller such as the 8-pin PICAXE-08M, use its PWM output to generate 4-20mA and set one of its analog imputs to take 0-5V (or whatever you need) control signal ..
Take a look at this example:
and see how simple and inexpensive it is ..
Regards,
IanP
4 to 20 ma circuit
try it:
it can tell you how 0-5VDC converte to 4-20mA,DC voltage isolated amplifier is a kind of IC that can convert DC voltage to output current or voltage that according to comparison with no relationship with load.
It also tell you how to design PCB.**broken link removed**
