0-50V 0-5A adjustable linear power supply
fjpompeo
Advanced Member level 1
Brazil
0-50v
Hi all!
Need a 0-50V, 0-5A adjustable linear power supply. This PSU will be used to power an UPS to be fixed in place of the battery bank.
Regards,
Fernando
mc1466
Hi fernando
Try this at h++p://www.a-and-t-labs.com/K2_Lab_Power_Supply/index.htm
All documentation is provided at left side menu in the page.
Pay attention: i think that exist a bug in electronics now article. See the schematic of power supply (hand draw schematic), its corrected version.
If a switched mode is ok : h++p://www.elecfree.com/electronic/circuit-power-supply-regulator-switching-0-50v-5a-by-tl494-mj15004/
Best Regards
Jackrs:D
adjustable power supply circuit
Here is a Linear Power Supply that will do what you want.
From Gary at Chemelec
fjpompeo said:
Hi all!
Regards,
Fernando
regulator 0-50v
circuit power supply regulator switching 0-50V 5A by TL494 , MJ15004
Added after 6 minutes:
Regulator 0-50V 2A by IC LM723 + Transistor 2N3055 & BD140 & A671
Circuit+power+supply+regulator+0-50V+2A+by+IC+LM723+%2B+Transistor+2N3055+%26+BD140+%26+A671.jpg
Q- 2N3055 x 2 for 5A current
adjustable power supply schematic
Thanks to all of you.
I have ellected the one with TL494 but momename how do I adjust current limiting? Read the article but there wasn't nothing about it!
Fernando
For the better quality of regulations (stability) vs load & line (& Temperature) changes...
K.
I think,
yes, but you see; its no more as a transistor & zener diode as hes Ie stabilizer...
K.
Yes but for an rf power amplifier an output voltage change in the class of milivolts, even 0.5v may not be a trouble.
Leaving alone the small ripple depended on temperature or load changes (in class-A amplifiers load is constant), do you think the simple zener-transistor psu above is clean in terms of noise or not?
Dr Om,
I think: yes, as wrote too, but Nois clening?
Surely not better as your AC-input, also I would see over all for apply good bypassings_ Elkos + parallel Ceramics...
Maybe Zener voltage need a ceramics too?
Good luck!
73 de Karesz
