gopalece
Newbie
I have designed a voltage divider network using diode connected mosfets(NMOS).The schematic consists of four diode connected mosfets.Middle two transistors substrate terminals are connected to source terminals.Upper transistor substrate terminal is connected to Vdd and Lower transistor Substrate terminal is connected to ground.I am designing layout for it. Substrate terminals are having different potentials.How can I connect substrate terminals in layout
