Archimedes
Junior Member level 3
So I have a capacitive vibration sensor, it drives Vackar oscillator frequency, but there's a problem: there's a large, low-frequency (<15 Hz) "common mode" capacitance that can shift the center frequency between 500-900 MHz. What are the best ways to demodulate the signal (5 MHz max deviation)? This definitely has something to do with AFC but I'm having trouble building a wideband frequency detector that will track the center frequency. I tried making a quadrature detector with low-Q tank but it loads input amplifier so heavily that the output amplitude drops to unacceptable levels. What am I doing wrong? I followed this paper to design it. Here's the schematic of input limiting amplifier and quadrature detector.
