deepshah3
Junior Member level 1
I am using pickit3 programmer to program my pic16f877a.
The problem i am facing is that,even after i am done with loading the whole program on to my chip,the CODE IS NOT RUNNING ON THE HARDWARE.
I have loaded a simple led on/off program.
I am using LVP method for programming.I have pulled the pgm/rb3 pin high(5 volts) using a 100ohm resistor.
What values must be loaded in the configurtion word??
Also when i check voltages on the port pins using a multimeter,I find 1.7-2Volts on every port pin.
What could be the problem here?Please help!!
