Single guardring for field leakage control, Double for
substrate carrier extraction (latchup). Closer is better
(until it affects breakdown / leakage at high Vdd) on
a simple ohms/square basis, "access resistance" to
the most distant channel point, as guardrings serve also
as body tie / "tap".
