using 74HC573 as Buffer
azadfalah
Full Member level 2
Hello friends,
if i connect LE pin to VCC Can I use 74HC573 as a buffer?
I do not want to use another IC
I need 3mA current
Additionally you need to connect OE to GND.
In the datasheet you will find this called "transparent mode"
I recommend to read the datasheet regarding "output voltage vs output current" to check if this meets your expdctation.
Mind: Don't let (unused) inputs floating. Not with this IC, not with anyother IC.
